RiverBottomOutdoors
Slipping the PVC over the seat pedestals......genius! Why the hell didn't I think of that????
[url=https://www.tinboats.net/forum/viewtopic.php?p=322924#p322924 said:RiverBottomOutdoors » Today, 09:44[/url]"]Slipping the PVC over the seat pedestals......genius! Why the hell didn't I think of that????
[url=https://www.tinboats.net/forum/viewtopic.php?p=325399#p325399 said:PSG-1 » Today, 09:11[/url]"]I agree with catman steve on this. Great Stuff is not so great, it is a water magnet. I had a lot of fun digging it out of my jetboat when I re-did it with the 4 stroke engine, as it was waterlogged, and stunk worse than a paper mill (anaerobic bacteria in the bilge) It also caused some corrosion to my fuel tanks, nothing to the point of leaking, but I did TIG weld some of the really bad oxidized areas on the tanks, just to be safe.
It MIGHT work if you blew it into some really heavy mil plastic bags, but if the bag gets one hole in it, the foam is going to soak up water like a sponge. They can advertise it as closed cell all they want to, but it's not the same thing.
[url=https://www.tinboats.net/forum/viewtopic.php?p=330086#p330086 said:DieagoMan » 41 minutes ago[/url]"]Great build! Good job! both of you
Ive been making my living fixing pwc's for the last 23 years and bikes before that. I do have couple questions ??? Ranchero are you still running the first original engine you got from SBT?
And PSG-1 Are you really sure you want to go to a 3 cyl 4stk from Bombardier?? I see supercharger failures at least once or twice a month and at least 2 engine failures a year but Ive only condemned 2 Yamaha 4stks sense 2002! I see around 150-200 pwc repairs a season here on the lake in Texas seems to me a Yamaha supercharged 1800 would be a far better choice.
[url=https://www.tinboats.net/forum/viewtopic.php?p=330098#p330098 said:DieagoMan » 8 minutes ago[/url]"]I would like to see your boat run the opti again and you have one of the skat trak or Riva pumps and stage 3 kits. The Skat trak twin drive impeller also looks promising!
they are a way more efficient pump and the stator design really does a great job straightening out the water flow.
I remember the tech rep at Yamaha telling me back in 2002 that they would never build a ski with a top true speed of over 65mph because they didn't want to get people hurt and he also said the worked on pump design to get great 0-65 acceleration but limit top speed! Is this him saying what he thinks or what he knew I don't know?
Think about it a minute. you know the big three pwc company's could easily build a 700-800 pound 100 mph machine if they desired to. Also I wished I was closer to Ranchero because I have at least one of every impeller Seadoo made from 1992-1999
I for kicks would lkie to see him try a 580 3 seater impeller or one from a 1994 seadoo explorer dingy 12 ft boat
Seadoo did change in 08 but they still want yo to service charger at 200 hrs instead of the 100 and if you go that route I hope your buddy has the candoo software to reset maintenance clock when you service so it dont keep annoying you. and the newest 2010 up I believe reduces HP if you don't.
[url=https://www.tinboats.net/forum/viewtopic.php?p=330086#p330086 said:DieagoMan » Today, 19:23[/url]"]Great build! Good job! both of you
[url=https://www.tinboats.net/forum/viewtopic.php?p=330104#p330104 said:DieagoMan » 6 minutes ago[/url]"]I'm no genius but Ive read you saying this before? Ive rebuilt several of the older yam thru hull why do you say it wont take it? on the gp's and XL's the bearings on the thru hull is not much different than the ones in the pump and they were direct drive.
I will have to look at the next sho i work on but ive never had any problem or payed any attention to the thru hull on 4stk. I will tell you this the VX is different I had to pull a drive shaft on one last year and it no longer pulls with the pump you have to raise engine like a kawasaki and pull it towards the bow under engine. Im also not a hot rod genius Im a mechanic the moneys in repair not racing lol hell I cant even remember sitting here what the rev limit was on a 1200 2stk lol wasnt it around 8000
[url=https://www.tinboats.net/forum/viewtopic.php?p=339501#p339501 said:Brine » Today, 17:37[/url]"]Least we forget... One of the coolest damn builds on here :USA1:
