Shoedawg
daschmetterling said:Good to know- i'll look into it. Thank you!wmk0002 said:riverrat717 said:Be careful foaming. High expansion rate with that foam. Far as a drain channel goes...you may want to use a pipe or conduit to act as a mold cavity to run to your drain plug. ANYWHERE you don't want foam, use lots of car wax on that surface and the foam won't stick.
Don't take this to the bank, but I think I have seen where a drop tarp, like for painting, was used to line the inside. Supposedly wax on top of it works well.
Sent from my SM-N900V using Tapatalk
I purchased some 2lb pour foam from US Composites a few months ago back (have yet to get into the pouring stage). For draining issues, underneath your floor, you can try using some aluminum flashing. They are sold in rolls of various feet and widths and very affordable.
Its pretty easy to bend, shape and cut too. Basically you would shape a conduit to run along the bottom of your boat, creating a drainage channel for water/clean up. See my second grade drawing below to understand what mean:
To keep the foam level with your floor, I would first add some plastic trash bags to the bottom of your floor first (tape it). From there, pour the foam over your choice of drainage/bottom side of boat (in my case, the alum. flashing) and QUICKLY place your floor over the foam (plastic bags down) before it starts to expand. Get some weight on the top of the floor and keep even pressure on it. Let the foam do its work, while watching for any rises/shift it may produce in the floor while it is expanding.
After the foam has cured/stopped expanding, then you can remove your floor and take off the plastic trash bags. The bags (per US Composites) shouldn't stick to the foam, thus given you a pretty even foam platform that will now support your floor and you have drainage as well.
You can then, mount your floor. I wouldn't use PVC piping for draining. The diameters (IMO) of most large piping just don't do that good of a job. Plus sticks, leaves and other crap can get stuck in them, impeding good drainage.
I am in the same boat (haha) as you are with floor thickness. I am leaning towards .090 myself. It seems most guys on this forum use that size for their floors.
