I got a gift card to amazon for christmas and bought myself a sous vide controller for my crock pot.
https://www.amazon.com/gp/product/B011296704
I use a cheap aquarium bubbler to keep the water circulating.
For those of you who've not heard of it before, you vacuum seal your meat into a bag
Submerse it in water and let the cooker bring it to exactly the temperature you want.
I cooked my steaks to exactly medium rare (135*) and let them sit there for 2 hours. Then quickly seared each side in an iron skillet.
The controller has a temperature probe that you place in the water, and it switches the crock pot on and off to keep the water right at the temp you set it too. Mine can keep the temp to within a 3 degree range, it would be 1 degree, but the heavy crock causes some overshoot, so I set my temp about 2 degrees less than I really want to compensate for the overshoot.
It lets you get the meat perfect all the way through. You can cook ribs or roasts for up to 3 days but hold it at medium rare so all of the collagen breaks down and its super tender, without being overcooked.
I just did salmon fillets at 130* and they were out of this world. Because you are cooking it in a sealed bag, the meat doesn't loose any moisture or fat. The salmon had the consistency of salmon flavored butter.
And the best part is you can seal it in with stuff like cedar planks
https://www.vacmasterfresh.com/fresh-bites-blog/sous-vide-cedar-planked-walleye/
Or fresh herbs, and it gets infused with the flavor.
I sealed in a sprig of rosemary with my steak, and the entire steak had a delicious rosemary taste.
I have a leg of lamb I'm going to do next weekend.
