Hooknhorns
- Joined
- Jun 11, 2018
- Messages
- Reaction score
- 0
I needed to go into the foam a good foot or more, so I took an aluminum pipe of diameter for the plastic tubes to be used. I put an edge on the pipe by cutting away the ID of the pipe to form a sharp edge and just pushed & twisted the pipe through the foam to make the needed hole. Wetting the pipe by dipping it into a bucket of water helped it cut smoothly. Removed pipe and starting snapping off the cored piece, if it didn't fully remove the core. Works slick.-CN- said:... you should be able to cut into it with a hole saw and then cut away enough material with a knife to get the pipe in there.
