Bought an Attwood auto float switch to add to my Johnson 750 cartridge pump. The johnson pump had previously been wired for simple manual operation as needed -- black wire screwed down to one battery terminal, brown wire hanging lose and touched to other terminal when needed to operate.
I have followed the directions on the auto float switch (one brown on switch to brown on pump, other brown on switch to battery terminal, black wire on pump to other terminal) and have tried every possible combination of wiring with the Johnson to try to get it to operate without success. I suppose i could have a faulty switch from the factory, but hard to believe.
Any suggestions or similar experiences? I'm far from electrically inclined, but can follow directions and can go through a process of elimination to attempt to narrow the problem, but neither worked in this case.
Thanks.
Thanks.
