c-dawg
My next door neighbor bought a boat with a 32#MK endura. It runs backwards.Can he simply reverse polarity at the battery?
[url=https://www.tinboats.net/forum/viewtopic.php?p=326263#p326263 said:c-dawg » Thu Aug 15, 2013 8:36 pm[/url]"]My next door neighbor bought a boat with a 32#MK endura. It runs backwards.Can he simply reverse polarity at the battery?
[url=https://www.tinboats.net/forum/viewtopic.php?p=328135#p328135 said:krawler » Mon Sep 02, 2013 12:32 am[/url]"]The motor has been disassembled and the magnet housing is 180 degrees out. Remove the prop, remove the two long screws that hold the motor together, do not remove but rotate the housing 180 degrees and reassemble.
MDCrappie said:???? - the housing positioning has nothing to do with the motor rotation. Otherwise, the motor direction would be dependent upon what position the armature stops when shut off.
