theyyounggun
Is it okay to have your battery and gas tank in the same compartment?
Ok thanks.spotco2 said:Just make sure that both compartments are vented if you do 2 compartments. If you just use 1 compartment then it must be vented as well. You can have the battery and gas tank in the same compartment with no issues.
