It actually pretty weight forward now. The middle/front of the boat drafts about 6" now, it's about 3" at the transom. There are three batteries and an on board charger in front of the boat (forward of the blue line under the rear part of the front deck), two blue Optimas and a ultra light motorcycle battery for the starter. The previous owner wired originally put the one battery up there and I haven't had the time to rewire so I put the batteries there for now.[url=https://www.tinboats.net/forum/viewtopic.php?p=359965#p359965 said:onthewater102 » 18 Jul 2014, 13:21[/url]"]
I've got a 14' alumacraft as well - I get up to 26 mph with a full load out and 2 people sitting on the rear bench out of only a 20hp, so your faster speeds with a 25hp are good. Key is to keep the weight in the green boxed area as much as you can - this is the section that rides in contact with the waters surface when you're on the plane (on my boat the blue line is approx where the water contact is made when on plane depending on how fast I'm going.)
Putting your weight forward stresses your transom to apply torque through the hull to lift the weight. Look to any bass boat design - the batteries, engine, occupant seats, livewell and gas tank are all in that green boxed region of the boat.
Sitting in the water your boat looks well balanced - though you'll know better than I where your load was when that pic was shot...
Not close at all, Atlanta Ga.[url=https://www.tinboats.net/forum/viewtopic.php?p=359986#p359986 said:onthewater102 » 18 Jul 2014, 15:28[/url]"]Where are you located? If it's anywhere near CT I'd be interested in the 25hp should you want to sell it when upgrading to the 4 stroke
LOL, yup. It's the whole kit too, impeller, housing, plate and gaskets. I'm ready![url=https://www.tinboats.net/forum/viewtopic.php?p=360450#p360450 said:onthewater102 » 22 Jul 2014, 09:04[/url]"]saves you $20 3 years from now...better than nothing
