- Joined
- Feb 3, 2023
- Messages
- 883
- Reaction score
- 858
- LOCATION
- Mead Washington
Can’t speak for the MK one, but the Battery Tender is a very easy twist lock. It is much easier than taking apart the connectors you are using. I have those connectors on all my previous trolling motors, but I called them UPS connectors, for it was the first thing I saw them on. You have to twist and pull them apart. On the the Battery Tender, it is just my thumb and forefinger and no effort at all. I should be able to handle it even if arthritis sets in.
Sorry should have been more clear about which Anderson connector series. I was referring to the SB series. Push straight in, pull straight out. No twisting required. I use them in areas that are somewhat protected from the elements.
The SB series run $6 to $12 per connector assembly depending on the current rating. The contacts are available for different wire sizes. They are not waterproof but, neither are some trolling motor connectors that claim to be.
It’s a good idea to invest in a quality crimping tools, ratchet or even hydraulic crimpers for larger wires. I probably still have one of the cheap slam bam hammer type crimpers around here somewhere but, I haven’t used it in years.
