brmurray
can these be wired to control 2 motors simutaneously? Would love to be able to wire to use 2 55 transom mounts at the same time. Thanks for your input.
stratosjoe said:yes But make sure you use 6ga wire or at least something heavy and don't run 27 miles with it on high. i have 2 - 78 lb 24volt Minnkotas on the rear with the bigfoot wired to the front plus a 24 volt foot controlled in the front (1500 acre TM only lake) With all of them on high youu can pull a water skier but the foot button does get warm if ran for a long period of time
