Cubman
I recently purchased a 14' V-Hull, and have been doing a few small things to get it ready to fish out of this summer. The previous owner did a pretty hack job, in my opinion, of installing the bilge setup. First, let me share a few pictures to help my explanation.
The red circle is where the fitting passes through the hull at the transom. The hole is about an 1" in diameter, and it is just below a flat piece of metal. This prevents any hex nuts from being tightened onto the fitting. The two red boxes mark where the bilge area is easily accessible.
Here is a shot showing the location of the fitting from the outside:
The fitting was just sitting in its hole when I bought the boat, I think that it was letting water in during deceleration (when the wake would catch up with the boat). Right now the bilge pump sits in the pocket on the left side of the first picture, and the hose (he used hardware store stuff, i will use actual bilge hose) ran diagonally up to the fitting. They make 90* thru-hull fittings: that would make the run of hose much neater, but I will have to find one locally. As I mentioned earlier, because of the location of the hole in the transom, I can't tighten the hex nut down on the fitting. I need to do this to create a good seal. Should I elongate the hole down, or patch the hole and drill a new one in a different location? If I elongate it, how would I seal the gap? Thanks.
