Bleumunkie's Tracker 1436
bleumunkie
Reading Area, PA
After spending quite a bit of time checking out all the amazing builds here, I've got a pretty solid idea of what i want to do.
Boat and trolling motor where acquired from in-laws that moved to Georgia and didn't want to take it.
Obligatory before pics:
(Please excuse the garage clutter. Boxes had to be rapidly moved to accommodate the boat.)
and here is the proposed layout:
Stock:
After:
back red = Bench height deck with removable rear cover.
front red = deck at half height to level front floor. Available storage underneath.
Green = foam between ribs, carpet board over top for level trip hazard free floor
blue = half height storage box.
purple = accessory shelf
Other non visible improvements will include livewell in center bench, and yet to be determined battery storage (most likely worked into front of center bench.)
I like it!! I see a gas tank in the rear, you didn't mention a motor. Is there one or if not, whats the plan?
I have a 1972 Ted Williams 7.5. I got it off CL for $120. I'd like to get something 9.9 and Water Cooled. But I've had this out on the water and it runs great, but loud.
If all else fails - I'll run it this summer and get a new 9.9
MinnowFaces said:
That's a cool looking motor. I've never seen one like that before.
Its very interesting. Its a 7.5hp Tecumseh air cooled engine with a water cooled lower exhaust in the leg.
Its very cool but quite loud.
This is with absolutely no cleaning at all when I got it home. The guy i bought it from said that he used it maybe twice and then moved, stored it in his basement since.
Once I got it home I totally believe him.
So I finally got to do some work on it this weekend. Bought some supplies and got to it.
So obligatory pics and such:
Got started with framing. Using 2x3's for framing. The idea is to flatten out the front, giving a low deck. Since its a 36" width in the bottom keeping it low is going to be important.
Stacking the 2x3's gives me the perfect height. I also added a center support to make sure it didnt sag.
Here is a bit more of the framing built out. Both from the front and side.
After plywood applied over the top:
cut a door for a SMALL area for rope etc.
and the whole thing is removable for cleaning and maintenance.
Other work not pictured - I laid down 1" thick foam board between the middle and back seat that will be for sound / supporting a thin board and carpet.
That's it for today. Sorry its been slow - I work 6 days and its been pretty cold here and my garage is unheated.
How did you get the proper shape when you cut your front floor to fit the contour of the walls?
Thx
Thx
You measure a few points along the length of the boat and play connect the dots with a slightly flexible piece to get the curves.
for example I first cut my piece square the length and width I needed. which was 47" long x 40.5" wide.
Then I would measure the width of the boat at some points along the lenth. I chose four points the two ends, and two about the 1/3 and 2/3 mark. Know how far these points are from one edge of the board.
for example, one of my points was something like 36" from the middle seat, and 36.5" wide. (not exact, just for example)
40.5" - 36.5" is 4". now you have to remove 4" of material at that point, but from both sides. so you measure in 2" on each side. Draw an X.
you'll get something that looks like this after your done.
Now, if you play connect the dots with a straight edge, you'll either end up too wide, have jagged cuts, or come off the wall of the boat a noticeable amount.
however, if you use something stiff, but flexible in a direction (I used a section of foam board I had left over) you can connect the dots and get a nice pretty arc like so.
I used a circular saw with a small blade to cut off my edges. Test fit, and make any adjustments. It probably won't be PERFECT, but it should get you **** close. I didn't have to make any adjustments because I plan on putting some thin carpet over anything which will fill in the small voids that where left quite nicely
Wow, a carpenter AND computer whiz!!! =D> If the women don't find you handsom, they'll always find you handy. :wink:
Thx
Thx
My wife says that she fines me handsome, but really I think its just to butter me up and get me to cross off more from the honey do list
So I've been fishing when I can, and working the rest of the time. So it hasn't been going very quickly. BUT I was very inspired by another mod on here (that is escaping me tonight) with the LED lights. So I HAD to do it myself.
I got the basic LED's at https://www.oznium.com. my boat is a cobble together for fishing so I didn't need the finished look of the more expensive ones, plus they were out of the green when I looked and i'm an impatient man.
I have not made it to making a panel yet, so I have a small 7A 12v battery inside an ammo can that I also mount my switch to.
so without further wait.....
My next step is to put clear silicone over the LED's and holes in the front to make sure everything is waterproof and not rubbing on edges.
But that's going to be tomorrow after I make a trip to the hardware store.
