Bow support bunk or bow roller.
Clint KY
Far west Kentucky
Recently I was loading my jon boat onto my cobbled together trailer and the bow got hooked under the bow stop due to the angle of the boat on the trailer. I have replaced the bunks and there was and is no bow support bunk. So when the trailer is on a steep ramp the front of the boat is on the bunks but the transom end is still floating making the bow much lower. I realize the answer is a bow support bunk or a bow roller to make sure the bow is high enough.
Here is the question: I could mount a 2X4 crosswise on the frame of the trailer or I could mount a bow roller assemble accomplishing the same thing. Is the support as shown below strong enough to remain upright when the weight of the boat is pushing against it? Or would I be wiser to mount a roller?
I have the exact same issue. I installed a keel roller/bow roller, but have noticed that the black rubber one has split in two in the 4 short months since it's been on there. I realized today while looking into it that it isn't supposed to support weight, though I had mine supporting weight. This afternoon I'm going to redo mine to sit a little lower and further back to simply act as a bump stop of sorts.
I myself recently adjusted my bow roller to work properly... It was basically sitting there in a just in case set up but now supports the bow slightly when loading and unloading which is making a big difference.
Use the cross bunk it will spread the load over a wider area. The roller will have more weight on a smaller area.
I like the bow support bunk.
I just wish there was a wider selection of styles and sizes to choose from. I've only ever seen that exact one that you posted.
I went with the longer bunks as well - distributes the load perpendicular to the support ribs (big bonus) and they run forward far enough to make contact on steep launches.
I made a device similar to the one shown below to stop bow hang-up problems on a Carolina Skiff that I had years ago. Might work for you. I made mine out of two 8 inch wheels that I already owned.
https://www.overtons.com/modperl/product/details.cgi?i=713752
Longer bunks would definitely be better, but when you have a trailer like the one below, how do you support the longer bunks?
At the point where the side rails and tongue come together put a cross bunk. Then the longer bunks can rest on or mount to the cross bunk.
X2
