First off, this is my first post, just signed up.
I've owned two aluminum boats over the past 35 years, one welded, on riveted, both built by Grumman in the 80's.
The welded hull was great, never a single issue with that boat but being a flat bottom mod v hull I decided in 1989 to buy a new 14 SSF, which is a riveted 14.4' semi V hull with a wood floor and walk through middle bench.
That boat was fine till a few years ago when it started to pop rivets all over. So far I've lost and replaced almost a hundred rivets. The heads pop off clean, leaving the rivet still holding the metal secure without any leaks but the fact that they seem to be corroding off has me a bit concerned. The latest has been its losing rivets around the transom seam, I lost 14 of them last week alone. Again, it never leaks, just the heads of the rivets drop off. The boat is not corroded, has no sign of saltwater use and never has been in the salt. I replaced the transom panel last fall, and I found a lot of corrosion under the wood as well. Nothing that was through the skin but it was pretty well pitted all over.
My thought now is to fix the rivets and find another hull, is there any one brand that's any better than the next? With the price of new boats being more than $3k for a bare hull, most likely I'm going to be looking for something used in the 14 to 16' range. Something that can take a 9.9hp motor.
I looked at a pretty nice Sea Nymph, the guy said he'd sell me just the hull, minus the trailer, but I'm concerned about it being too heavy for a 9.9hp? https://southjersey.craigslist.org/boa/4562179743.html
I figured that I could toss the console and the heavy seats and use it as a tiller boat. The seller is willing to let it go minus the trailer for $1200 cash. Its a welded hull with some rivets.
Is Sea Nymph an OK hull? Someone here told me that they were the same as Lowe and Grumman in those years?
I've looked at several boats and what stood out about this thing is that all the decking is aluminum, it has no wood to rot and it feels pretty light.
