chrispbrown27
I am thinking of modifying, not removing the center bench seat. What I am thinking of doing is cutting the bench in half, cutting the side pieces off, and folding the top down to cover the section that is now exposed. Basically leaving two separate seats, one on each side. I am thinking of, before I do the first cut, running either a piece of flat bar or some sort of thicker aluminum strap across the top of what will be left to anchor it in place to maintain the structural integrity of the boat. The straps or flat bar will be ran down to the nearest rib and attached there, either by riveting or welding. The idea is to open up a center walkway but leave seats in the center for passengers and also put hatches in the new seats for the batteries to go. Do you guys think that the straps/flat bar will add enough support to maintain the integrity of the hull?
Chris
Chris
