Hanr3 said:
I use a Schumacher Ship N Shore charger. Its a portable unit and has a 2amp, 10amp, and 15 amp settings. I use it for my riding mower, boat, and car batteries. Worth the $50. Its mirco processor controlled, auto shut off, trickle charge if needed, plus it will tell you the current charge status level of the battery, has a diagnositc mode.
I've got a question for you and russ then, excuse the hijack. When you leave your charger on, does it say 100% for a long time before shutting off? And when it is no longer charging, does it completely shut off, or does it just switch to a different high pitched whine?
I can't decide if mine is screwed up or not. It never behaved quite right, then it experienced a flood in my basement, but it still seems to work okay, and it charges the batteries. I've just never trusted the auto shut off, because it will say 100% with 13V, and still charge for another 2 hours, still giving the same read out. When it finally does stop charging, it will alternate between the whine when its plugged in but not connected to a battery, and the charging whine, switching every 5 seconds or so.
