Greetings all! Thank you for allowing me to join your group! I have just purchased an older 15' Alum. fishing boat via Craigslist. It has a 35hp 1975 Chrysler outboard on back. The guy I bought it from never touched it, so it's been sitting in his yard for 5 years. He said the previous owner thought the issue was with the coils. I have successfully found and partially installed two new coils. For one of the coils I simply swapped the wires from the old one to the new one. However, I'm not sure which wires hook up to the second coil. Also not positive I have the correct wires on the first coil. There is also a missing ground? wire (see pics).
