When I took the boat from the cottage, I took dad's old 2 HP Evinrude also.
It's a 1980 model, although he always though it was a 77 since that's what the old guy up the road told him when he gave it to him (yup, it's been free twice now).
Dad used it a little bit, but wasn't much for routine maintenance so it ended up tucked in a corner of the cottage crawlspace. Used in the Atlantic and crammed into a damp dirt crawlspace. I'm pretty sure I remember him loosing it over the side once too.
So you know what it was like when I pulled it out: Locked solid.
I chucked it in the bottom of the boat, hauled it home and it's sat on the motor rack for couple years now.
I figure it would make a nice "backup" motor to hang off the transom since it only weights about 15-20lbs with a tank of gas. The bottoms are nearly all rock here and the 2 HP would beat rowing back to the launch any day! So I haul it over to the work bench and give it a look over.
Yup, hanging on the motor stand hadn't made it any better. Still locked solid.
I pull the motor cover off and there a tiny bit of movement in the flywheel. As I wiggle it back and forth I can see the prop move. So it's all good right down the leg.
Piston, gotta be the piston. Likely the rings are rusted.
So I try and pull the spark plug to soak it down with penetrating fluid.
Nope, spark plug it not coming out. A little heat and cold and I get it to turn, but it immediately drops a couple degrees off axis with the hole threads.
Not good.
I finish pulling it out and it's obvious the plug was either jammed back in until it grabbed or the threads has rotted away in the wet. Oh well, nothing new and an easy fix: thread insert will fix it up just fine.
After a week of soaking I try to turn it. Nope, locked as solid as day one.
Well, it's probably knackered, so I pull the head off to look. Not too bad in the bore actually. I drop more penetrating in the bore (piston is above the ports) and walk away for another week.
Try it again: nothing. Still locked as bad as day one.
I grab a wood block and give it a rap on the piston. Hard as stone. The wood actually splits.
Oh Boy, this is beginning to look like a rip it down only to throw it away job.....
So, time to get aggressive.
I figure the piston and bore are going to be junk, so I grab a piece of steel bar that's just a smidge less wide at the piston and then start whacking it with the hammer. Surely the rings will break, the piston will crack and the bore will scar I'm thinking.
After a half hour of this, I get a MM or so of movement. Keep the oil to it, keep pounding.
I eventually get the piston to bottom, but it's still solid.
Oh great, not it stuck at the bottom of the bore and no way to pound it back up without beating on the crank weights or the aluminum rod cap. That's not happening.
So I grab a great big rubber strap wrench and reef on the flywheel.
Creak!
A MM or so of movement.
And so it went. Creak up, hammer down.
After another hour of so, the piston finally gives up and turn sort of freely. I whip the con rod bolts out and drive the piston out of the bore.
Surprisingly, the bore looks great. Just a small stain of a rust ring where the rings had sat.
The piston tells a different story.
Aluminum corrosion had gotten a foot hold near the top of the ring lands and that was what was holding it fast in the bore. The piston rings had also been oxided into place an would come out with out breaking them.
Once apart though, it all cleaned up well and is in good shape. The rings snapped like dry twigs. A set of gaskets, a hone and new rings should fix it right up.
One depart from stock will be I'm going to paint it white and put the 1989 Johnson 2 HP Colt decals on it. This way, the color scheme will match the repop decals on the 8 HP Johnson.
Doesn't bother me changing it from Evinrude to Johnson, the 2 HP motors were the same across the board as they're all OMC so no big deal. I think the 2 HP was the same almost forever anyways. I've seen a 71 that looked just like my 80, and the 89's I've seen look the same also. Guess the 2 HP was low end market enough that it wasn't worth changing it until they changed hands Bombardier and different suppliers were sourced...
