Zum
May be even simpler...
Is the vent open on your gas tank;lets air in?
Sounds like it will run,if fuel can keep coming.
clarego said:duuuuuuuuuuuuh #-o #-o #-o what is wot :?: im new
Captain Ahab said:clarego said:duuuuuuuuuuuuh #-o #-o #-o what is wot :?: im new
Wide Open Throttle
One thing to consider before removing the oil mixture apparatus is that some engines employ a variable mix ratio that changes depending on the RPMs. At high RPMs you need to use more (I believe) oil to fuel ratio so that injection unit will change your ratio automatically. This allows for better performance then a simple pre-mix where the ratio never changes
From the 1989 Merc. manual:
"Operation of the Oil Injection System
The oil injection system delivers oil mixture on engine demand, from 100 to 1 at idle to 50 to 1 at wide open throttle."
So you DO NOT want to remove this and just use a pre-mix - it will effect your engine performance
