Got her hauled home today! Excited to get started on the overhaul!
View attachment 2]]
Sent from my iPhone using Tapatalk Pro
Thanks you sir, looking forward to fixing it upLDUBS said:It really is a nice looking rig. Congratulations.
It runs on premix fuel, the trailer was bought from a storage unit with the sole purpose of hauling it from the coast to his house. It is in decent shape but I might find a replacement because it does need some work, probably new springs, lights, etc.thedude said:Lots of potential! Check that trailer close before you take it far. If the boat has been neglected then the trailer probably has too.
I'd do new plugs, impeller, new fuel lines/bulb primer, lower unit oil. Does it have an automatic oiler or does it run on premixed fuel?
Yes sir that’s the plan, compression testing is happening Friday morning and then will start replacing things. Should I be worried about the oil near the top plug? Seems to be from the seals maybejethro said:That's a nice setup and the motor looks clean enough. Replace the water pump, thermostats and fuel lines and see if you can't fire it up.
WesTex1 said:Yes sir that’s the plan, compression testing is happening Friday morning and then will start replacing things. Should I be worried about the oil near the top plug? Seems to be from the seals maybe
Haha ok thanks!jethro said:WesTex1 said:Yes sir that’s the plan, compression testing is happening Friday morning and then will start replacing things. Should I be worried about the oil near the top plug? Seems to be from the seals maybe
I don't really know what that oil would be from? Seems unlikely it would blow by the plug, and it doesn't seem like a horrible amount.. I think I'd tend to not be worried about it until it becomes time to worry about it. :shock: If that makes sense.
I will have to look at it a little closerthedude said:Are you sure it's bed liner and not textured paint? I would not invest any time or money in painting bedliner. It will expand and contract with temp changes and likely wouldn't hold paint.
I definitely lucked out on the dealTMO8853 said:Man all of that for $800! I get on craigslist everyday and check my local area and it seems everyone wants 7-8K for their 2003 model boats. Great find!
