As long as you can turn the alternator It will work. all he is doing is using a small draw from the battery to cause the fan motor to spin at 3000 rpm at that point the alternator will produce the amps to recharge the battery. It will work just like on a drag car. The alternator has three main components: The Stator, Rotor, Diode and a voltage regulator. When the alternator belt or V-belt spins the pulley on the alternator, the rotor inside the alternator spins ... fast. The rotor is basically a magnet or group of magnets that spin, with all that speed, inside a nest of copper wires. These wires are called the stator. The next step in the chain is a diode assembly that changes the electricity from AC to DC current that your battery can use. There is a final step in the chain, the voltage regulator. In modern alternators, this is a built-in component. Back in the day voltage regulators were big black boxes that had to be bolted somewhere under the hood and wired into the system. The voltage regulator is basically a gatekeeper that will shut off the flow of juice to your battery if the voltage goes above a certain level, usually 14.5 volts. This keeps your battery from getting overcharged and cooked. That's it! As your battery is drained, current is allowed to flow back into it from the alternator and the cycle goes on and on.
