tripwirenh
Can you run say 2 12v outlets in series? Basically I want to reduce wiring back to the battery by running the outlets in series. Is that something I can get away with?
Also when I run my switch panel, I wanted to run the negatives of my nav lights and cab lights in series, but the positives would go back to the switch panel individually. (to control on 2 separate switches) Is this also something that is possible? I wasn't sure if anyone else has done this or if it can be done.
