Kochy
Wanna trade?? LOL Yours is so much more Bada%$ then mine, good job man!
Vinyl cutters appear to be pretty expensive. I don't see why I couldn't cut with razor and straight edge. Thanks.[url=https://www.tinboats.net/forum/viewtopic.php?p=338211#p338211 said:EricZ » 07 Jan 2014, 22:55[/url]"][url=https://www.tinboats.net/forum/viewtopic.php?p=338207#p338207 said:DrNip » 26 minutes ago[/url]"]What is the product you used to make the stencil on the boat? Where did you get it?
I bought a 50 yard roll of Oracal 810S vinyl paint mask and cut out the stencils on my vinyl cutter. Here's the link, it's pretty easy stuff to work with.
https://www.uscutter.com/ORAMASK-810S-Spray-Mask-Stencil
[url=https://www.tinboats.net/forum/viewtopic.php?p=338271#p338271 said:13rannon » 09 Jan 2014, 11:53[/url]"]Discovery channel should offer you a show for building custom boats. Nice work!
I noticed you had a lot of dead space around the rod holders. Looked like it could hold a lot of spray foam if you were worried about it sinking.
I just skimmed the pictures so I don't know if it had been brought up before.
[url=https://www.tinboats.net/forum/viewtopic.php?p=338325#p338325 said:crabsandbottlecaps » Yesterday, 09:59[/url]"]What type of foam is that looks like something you would see on a house under siding ? If so how does it hold up and does it get soggy . If it's not what is it and where can u get it
[url=https://www.tinboats.net/forum/viewtopic.php?p=338642#p338642 said:crabsandbottlecaps » 14 Jan 2014, 11:34[/url]"]Thanks and how did u get it to stick on upright and I take it u just layer on floor but did u use some type on silicone to stick
[url=https://www.tinboats.net/forum/viewtopic.php?p=339198#p339198 said:zacksimpson » Today, 17:09[/url]"]I never really checked while I was taking my boat apart, but now with all the original foam out and the decks, it's very flimsy on the front end. I'm wondering if you still have this problem with there being no spray foam? I know you added a lot of aluminum bracing to yours, and I'm going to be adding some to mine, but I was just curious how much stiffness was gained by having spray in foam? I'm debating just doing under the front deck and those two back portions under the rear deck in spray/pour and the rest in pink board. For the price, and ease of it, I'd rather do all pink foam, but if it'll make the boat stiffer overall, I'll do some pour foam.
[url=https://www.tinboats.net/forum/viewtopic.php?p=339218#p339218 said:Kier » 21 Jan 2014, 00:51[/url]"]Is a pool noodle considered closed cell foam? Can it be used for floatation?
[url=https://www.tinboats.net/forum/viewtopic.php?p=339243#p339243 said:Kier » Today, 09:57[/url]"]I assume the pink board foam is cheaper than pool noodles?
