According to your pics that were submitted, it looks as though it is a solid state ignition motor. I happen to have a repair manual for year and model. Check out https://home.earthlink.net/~brixent/index.html you can either call or email. The man is a tremendous help when it comes to these motors. I can say from personal experience that if the stator is trashed it will run $225/$250 for a new one if he can find one. Also under the flywheel is a plastic collar with a magnet in it that can dissenegrate over time. If this is the case you are SOL, the part is no longer available and best bet is to find a donor motor. I have been having good luck on Ebay for finding parts (I have a 15hp Gamefisher with the Tecumseh motor), there are a couple of sellers that have parts available but can get fairly pricey. A little FYI on the donor motor thing, 7.5, 9, 10 , and 15 horse motors will all have the same plastic collar with the magnet as long as it is a Tecumseh motor. The Stators however will be different. Good luck and let us know how it turns out.
