[url=https://www.tinboats.net/forum/viewtopic.php?p=326925#p326925 said:
therobzilla » Today, 00:43[/url]"]No need to hunt down ethanol free gas, remove the ethanol yourself it's very simple.
Pour 3 gallons of gas in 5 gallon bucket, pour 1 gallon of water in gas in 5 gallon bucket use a gallon water plastic jug, this equals, 4 gallons total.
Stir rapidly the water and gas for about a minute or two.
Cover bucket with old tee shirt so nothing gets into bucket.
Let sit covered for about 5 minutes. Until water/ethanol have separated from gas, it will sink to bottom of bucket, won't be able to see separation if bucket is not clear, however it has separated but it is below gas.
Get some clear 3/8-5/16 hose from Lowes/Home Depot.
Set 5 gallon bucket on something like old cooler or something so it's higher than 1 gallon water jug, make sure not to move 5 gallon bucket too much when you elevate it, put clear hose carefully down side of bucket so it just touches bottom of bucket. Siphon into gallon jug, your gallon jug will fill with water/ethanol mix that has been washed from gas.
The gallon jug will fill more than 1 gallon of water/ethanol mix, when gallon jug is filled stop Siphon hose with finger don't loose Siphon, get another 1 gallon water jug and keep siphoning until you see the color of mix look like gas. Stop Siphon.
The first gallon is all water/ethanol mix you can dump it down your toilet if you want, it's no different than basically grain alcohol, the second gallon will have a small amount of gas on top depending on how quickly you stopped.
You now have ethanol free fuel, mix your oil, add your fuel stabilizer, put in empty gas can and go boating.
It takes very little time to wash the gas.
JUST DON'T DO IT IN CLOSED CONDITIONS, I DID IT IN OPEN DRIVEWAY.
Don't believe me, Google removing ethanol from gas.
