WidespreadPanic
- Joined
- May 20, 2018
- Messages
- 3
- Reaction score
- 0
Hi All,
Got this motor off Craig's List. Runs, changed coils, need to clean/rebuild carbs and check crank/gear and impeller before I take it on the lake. Been converted to regular fuel tank already when I bought it.
Question; Will the FDE-11 starter bracket and starter motor fit this FD-11 manual pull motor? Any caveats I should know about if it is not a straight forward conversion? Electrical should be fine, but advise welcomed.
Essentially thinking of replacing the manual bracket with this bracket and starter... https://www.marineengine.com/newparts/part_details.php?pnum=OMC0175019
Is the L/P 3.00 going to be in the way, necessary.
Additional question: What is the L/P 3.00 part, (number 77 and 78 in the diagram here https://www.marineengine.com/parts/...manufacturer=Johnson§ion=Carburetor+Group? Its the 'clam shell' two half tank... Air or fuel....? Is it part of the old fuel system? Curious as I did not see it on a a running FDE-11 you tube video.
Please forgive my ignorance on this specific motor. I'm fairly mechanical, mostly auto's and motorcycles.
I replaced the keyway on the shaft with an OEM key. Replaced the coil spring for the pull start, but spring keeps popping/unwinding after a several (20 or more) pulls. Would really like to have electric start and the pull only for emergency backup.
I appreciate any help.
"Bear gone fishin', mermaids missin'
Got to get to the bottom of this" - WSP
