OK so I'm at a loss on this motor right now. I installed a fuel pump kit and cleaned out the carb. The motor runs but very rough. I narrowed it down to the top cylinder not having any spark. The lower cylinder has a very bright, strong spark. I popped off the the flywheel and the coils, condensers, and points look brand new. I tested the coils for resistance and both tested out fine(both windings). I checked the plug wires for resistance and they were both fine. I then switched the coils, installed the flywheel and still same result. Bottom spark top none. I then switched the condensers and cleaned the contacts on the points and tried again. Again same result. :roll:
Not sure what it could be. The only thing i can think of is maybe for some reason there is an interference with the magnet when it passes over that side of the motor. The coil location in question would be the one right by the carb., the one farthest from the carb. seems to produce a great spark.
