Exide Nautilus Marine Deep Cycle any thoughts?
ol sarge
Central Wisconsin
I am thinking about buying this battery to run my 55 lb thrust Minn-Kota Traxxis on a 14 ft v hull. The book let states to run the motor you should buy a battery with at least 115 amps. I just want to make sure that this is a proper battery. A local sore just got these in and are selling for $69 with a 12 month warranty. The motor is my only means of propulsion.
Exide Nautilus Marine Deep Cycle line provides continous operating run. These batteries are designed to provide continuous operating time to run trolling motors, live wells, inverters, depth/fish finders, etc. They can be discharged and recharged many times without damaging the internal components of the battery. Price shown is with exchange of old battery.
550 Cold Cranking Amps at 0 degrees
675 Marine Cranking Amps at 32 degrees
182 Minutes Reserve Capacity at 25 A
105 Amp Hours (Ah) continuous operating time.
182 Reserve Capacity.
Lead/antimony construction
Enveloped separators surround the plates
Thicker grids designed for many cycles.
Stainless steel threaded and SAE posts provide ease of installation and permit uncluttered wiring harness for electrical connections.
12 month warranty
Thanks.
