Douglasdzaster
- Joined
- Sep 19, 2020
- Messages
- 783
- Reaction score
- 469
- Location
- Smithville,Texas
- LOCATION
- Smithville, Texas
Hello everyone, this is about my third thread since all this started. I found a Jon boat a while back to fix up and go fishing. I did the motor work first instead of checking other things like I should have being my first aluminum boat. I got it going and had been using it a lot.
The more I learned about aluminum I decided to pull the floor and clean under it. Looks like it was coated with either roofing material or bed liner I could be wrong. I noticed pitting in the cross members and decided to just redo the bottom if not paint the whole boat. The boat never leaked but I have found several patches and bumps it must have received on the near by river. Anyway water was staying under the floor after it got wet and was moist when I removed it so I think that’s the source of the corrosion. Unless the po used it in saltwater.
The more coating I removed the more I found. Some spots even looked like rust but aluminum doesn’t rust I’m told. So I kept on going taking it to bare aluminum. My questions now are what should I fill in the pitting and old screw holes with all corrosion is removed? I’d like to use something that will help the cross members stay strong if possible. Pitting on the actual floor is shallow thank goodness. And as I get to the bilge area there are places I can’t get to. What do I do there? It’s taking me over a month due to having to work outside with the weather here in Texas. I now have a cover that I use when not working on it and for when I’m finished. I pal on putting a floor back in that’s easy to remove and keep the bottom clean and dry. When I started this I was advised to leave it alone since I stay in freshwater but other things I found and had to redo that the po had done made me worry about the corrosion continuing to eat it like a cancer.
. Thanks for any advice or opinions. Oh the actual holes in the cross members are from rusted broken screws that attached the floor which were rusted and I removed what was left of them with a Dremel tool.
