Well,
First thing first, the Transom board needs to be replace in order to get the boat in the water.
I got all 6 new screws with nuts and washers, I also got 3M 5200 sealant and Acetone to prep the surface.
The 3M sealant I had to buy at Lowes, a whole tube for $13, but I also got a smaller tube at walmart for $7.
The big tube says it must be used within 24 after being open, there is no way that I could use that whole thing
in so little time, so I think the smaller tube will do the trick for the small job that I have pending.
I got a piece of 1 x 12 x 36 treated wood which I am going to cut to 1 sq ft, painted with black paint and then
glue the edges just before I secure it with the bolts and nuts. I am painting with Oil based paint that I got from Lowes
to paint a metal trailer that I used to have, not sure how this paint will do on the wood and water. also, I am not sure how
the sealant will adhere to the fresh oil paint on wood.
I saw a sealant at walmart, 3M 4200 that says it is medium strength and it dries quicker the the 5200, I wonder if that would be a better choice for the small job I am about to do.
Once the boat is ready, I am just need to figure out of a better way to load it on to my utility trailer so that it will be more easy to load it and launch it. Any ideas, bring them on....
Here is a picture of the piece of wood that needs to be replaced.
