First timer...
Caesar
Eastern Iowa
Just picked it up today, a 1978 Rhyan Craft with a '99 25 horse 2 stroke Johnson to get me around the Mississippi. Seller listed it as a 1650, seems like kind of an odd width... Regardless I'm excited! I've been lurking around here for about a 2 weeks now reading just about everything that's been posted, I've picked up plenty of ideas. Can't wait to get it out on the water, and can't wait to start making my own mods. I'm at work now, but pictures and plans will soon be posted. Look forward to your guys thoughts and suggestions!
Ok, my first question, trying to upload some pictures, but I'm told the file sizes are to big... Any suggestions on how to shrink them?
Welcome Ceasar! 1650 is a little odd, give it a measure and find out for sure. Perfect boat for that river.
I'm originaly from eastern Iowa also, right on the bank of the ole Miss in Camanche. Some good fishing there! Was there just a few week's ago. Couldn't fish though. Ice sheet broke loose from around Fulton Ill and packed the shores about 20 feet out with jagged block's of ice. Darn the bad luck!
as far as resizing goes,
Open up a new photobucket account - it's free. When you download pictures to that website, it automatically sizes them in the format that works great with this site. Then all you have to do is copy the last statement and post that link in this window - it will automatically post.
If you upload pics to this website, there is the possibility of losing them depending on if and when Jim decides to change servers. It may not be a factor now, but Photobucket is just like an external hard drive for you...
If you upload pics to this website, there is the possibility of losing them depending on if and when Jim decides to change servers. It may not be a factor now, but Photobucket is just like an external hard drive for you...[/quote]
I didn't know that :oops:
I've been resizing all my pics before sending them to photobucket #-o
Ok, let's give this a shot...
Side view... I think the first project will be to rough up the paint, prime and then re-paint to some sort of a matte tan-like color.
From the bed of the truck... Project #2 will most likely be ripping out the current flooring (which is getting old and a little bouncy), center bench, and most likely front flipping deck. Then building a similar deck in place of the front deck. Then building a rear deck that's about the same size that covers the rear bench. Then because the middle bench will be gone, I plan on building a set of rod/gun/oar lockers that run the length of the sides between the front and rear decks; these will double as benches for riders. Once everything is framed and built, the plan is cover everything with marine carpeting.
Casting deck and container which currently houses the cranking battery for the outboard. Fish finder and nighttime running lights are all wired to this, I was told that all would be fine... I think I'll eventually get a a separate battery and a switch panel for all of the accessories (lights, ff, bilge pump, livewell). Any thoughts. Also, I'm in the process of securing a foot controlled trolling motor to mounted on the casting deck. From what I gather it should have it's own separate battery? So by the time I'm done I'm looking at 3 batteries up front, a deck, a trolling motor, and me. Seems like a little too much weight, I may end up moving the cranking battery somewhere else...
View from the stern...
The great thing about this boat, is that it is most definitely fishable that way is right now. Solid transom, no leaks, outboard runs well (most defects are cosmetic). But there's also a lot of things that can be done to customize it, and make it really look good. I plan on fishing the way it is and working on it when I can't fish. Which will most likely be rainy weekends. Let me know what you think...
Are you using photobucket to put these on?
If so, the link to the pic should look like this...
(IMG) the (...) should actually be brackets [ ] then the url https://i15.photobucket.com/albums/a382/russ010/0302200905300.jpg... ending with (/IMG)
so in essence it should go... (IMG)https://i15.photobucket.com/albums/a382/russ010/0302200905300.jpg(/IMG)... just make sure the ( & ) are [ & ]
it's hard to do this when it will automatically embed the image
https://photos-e.ll.facebook.com/photos-ll-snc1/v2739/202/106/123700142/n123700142_30923756[img]
ok, above is what you should have... but you have to have an actual .jpg or some other extension saying it's an image.... I tried making that url a .jpg and it still doesn't work. I can't help you out much with facebook stuff
depending on the trolling motor I wouldnt worry about a third battery. the finder doesnt take much juice, the bilge pump and livewell pumps wont be running all the time.
***UPDATE***
Project number one completed! Took about a week and half to prime and paint. Went with Pettit's Shipendec in "Dull Dead Grass." As previously mentioned I wanted a flat, no gloss finish and this turned out exactly how I hoped it would. Apparently "Dull Dead Grass" is Pettit's take on olive drab. I'm not a duck hunter, but may eventually get into it, so I figure an OD like color would be most practical. 3 coats of primer and 2 coats of paint I'm a happy camper! Took 'er out on Saturday to a couple sloughs and backwater areas on the Mississippi, needless to say I was a little more concerned whenever I ran over a log back in the shallows...
Now to the fun part...
Primer
More primer. Decided against re-painting the rail since it would only get chipped and rubbed off by people, fish and other things going in and out of the boat (Disregard the wife being silly in background...).
As I said earlier, 3 coats of primer, 2 coats of "Dull Dead Grass" marine paint, a fresh set of numbers and we're back in business, although I'm still picking OD paint out of the corners of my fingernails.
Nice to see another Rhyan Craft on here. I've only seen one other and it was a V-Hull, and it turned out great. I'm thinking about a coat of Herculiner on the gunwale for the same reason as you with it chipping.
Your boat looks good.
Zum, I may end up stenciling some sort of pattern eventually, but for now I'm pleased with OD. GrumMan, I'm just a little further South of Cammanche, thinking about hitting up the Wapsi tailwaters this weekend. If I end up going there I'll let you know how I do. Now that I've got it painted up, the next project will be decking it out. There's a small deck up front, but the wood is starting to go. I think I'm going wait a month or so, I figure I'll fish out of it as it is right now and that may change my plans a bit. BUT, here's what I'm thinking/planning on right now.
I've thought about ripping/cutting out the middle bench, but upon further thought, I've decided to keep there and instead build and elevated deck from the front all the way back, covering the middle bench.
My next thought is, If I bring the deck just below rail, I'll have about a 3 inch difference between the top of the bench and the bottom of the decking. I'd like to build a set of lockers running on either side, stretching from the front of the rear bench, up and over the middle bench, ultimately stretching 8 feet. I figure this will allow me to put my life jackets, throwables, etc in the rear half of the lockers, put the rods on top, close 'er up and be ready to roll. At 18'' wide, this would leave me a 3' wide floor in the rear half of the boat.
Then I'd like build a rear deck basically covering the rear bench. A couple of hatches (open on the inside for ventilation) would cover the gas tank, and make for much cleaner look.
Like I said this is what I'm thinking at the moment. It's all subject to change, and if you guys have anything thoughts or input I'd enjoy hearing them.
