Floatation foam
Perhaps you have a lesson here...are you going to take it seriously ??
It would take some serious boat surgery to get to and replace the foam, everything is welded in my boat. There should be a better, more permanent solution for boat flotation.
No ill intentions meant there, but hopefully your life doesnt depend on that foam being good. Some years back a fellow couldn't get to his bad foam out for the same reasons. Only a small acess hole, so....squirted some acetone in there, instantly melted the foam...after a thorough drying injected more good foam. As luck would have it, he didn't have any leaks after that !!
