macawman
Having an issue with the crankshaft woodruff key being shared off by the flywheel on my 56 Johnson 10 horse. When the key is inserted in the crankshaft slot, it only protrudes about 1/16th inch which is less than half the depth of the slots in the timing Cam and flywheel. Is the OEM version of this key "taller" then a standard, off-the-shelf 1/8th inch woodruff key?
