wmk0002
I probably already know the answer to this, but anyone else had problems with this new style EPA compliant cap? Its what came on the Moeller 3 gal tank that was included with my Yamaha F25. Motor randomly starves for fuel at high rpms, which is why I'm not really concerned it's anything motor related. On this style cap you have to press down and vent the tank every once in a while even in the run position which is obviously extremely annoying. ![Moeller Tanki Cap.png Moeller Tanki Cap.png](https://cdn.imagearchive.com/tinboats/data/attachments/103/103259-bca8dd1a7e50cd3edd521bef28f4884f.jpg)
I just bought ones of these manual vent caps to replace it with. I'm pretty confident that will solve my problem. It's just weird to me it seemed to work ok for a few years and is just now doing this. Anyone had any luck modifying the cap it came with it so that it vents properly? For the 3 gal Tohatsu tank I have, the dealer drilled a hole in it somewhere which allowed it to breathe and work like it should, however, it will seep fuel out now from sloshing. Would be nice if the modification would allow the red piece would still close it off in the closed position and then when it the open/run position vent normally and not act like a check valve.
![Moeller Cap 2.jpg Moeller Cap 2.jpg](https://cdn.imagearchive.com/tinboats/data/attachments/103/103262-da3dcd2667dadbb6581081886f798185.jpg)
