LarryA
Getting a plan together for wiring for my boat. I was looking at the paper from the front running light and it calls for a 2amp fuse. I'm going to wire both the running and stern light togther on a 3 way switch. What should I use for a fuse amperage considering both lights will be on the same circuit?
Also, does anyone know what I should fuse a Rule 500 GPH pump at?
