static
ok I read before I ask. Im new to the forum. I have a 1961 18hp evinrude, on this site it says gas mixture is 24:1 I was told 50:1. I was on the water trying it out, I have to hold the choke and pull the chord at the same time because the choke isn't working. it slides back in if you don't hold it. so anyways it started, I held it for about 15 sec- let it go it sputter for a little while then it shut down, after that I could not get it to start. I'm a xerox tech don't know anything about boat motors, the plan is to change the fuel filter, plugs & gas pump. any ideas?
