Gluvit epoxy
CalicoJack
Port Orange, Florida
So I ordered some Gluvit epoxy and when I opened the can it was only half full. Is this how it should be? Just checking to see if this is normal. The stuff isn't cheap...
    125.4 KB
Did you receive the second container, which is the catalyst? If so, i catalyst is mixed in this can, hence, why it is 1/2 full. If not, then you only received 1/2 the product.
I agree....it is NOT cheap! Therefore, only mix what you need according to mixing ratios, which if I recall, is 5:1 (resin:catalyst).
Yes, I received the two containers. I was just stumped when I opened the can.. I thought they had run out epoxy and sent me what they had left lol
