Should work fine.
GTS225 said:It might be better to arrange a light spring or gas shock to turn your trolling motor, should you no longer have control. This would cause your boat to travel in a circle, and would keep it in an area that you could easily get back to it, as well as calling attention to your plight, should you need assistance. You'll also have to fight the constant spring or shock pressure, but.....
Roger
TNtroller said:Why not just use a rod leash and attach it to you and the yak. If you fall out, then you don't get separated from the yak.
