tracmanRocks
- Joined
- Jun 18, 2024
- Messages
- 3
- Reaction score
- 0
- LOCATION
- Coeur d'Alene ID
I have an older 14' aluminum boat that has no identifying numbers or information.
I have done a lot of research online but have not seen this exact boat. It looks most similar to older Smokercraft / StarCraft boats but the corner caps on the transom don't match other Smokercrafts / StarCraftsfrom the 70's. Previous owner inherited this boat from a friend who died so no registration info.
Located in Spokane, WA area
Could this be a JC Penney Foremost? Is so, any idea who the actual manufacturer might be?
Length is 13'10 (transom to tip)
Semi V hull
Bottom is relatively flat after first seat
Transom width 53" / 15" height
Beam 63" outside to outside / 60" inside to inside
22" deep at mid hull
44" bottom width
Bench seats filled with flotation
One piece bottom with three running strakes
Semi V hull
44" bottom width
