RivRunR
My MK Edge 40 bow mount started making noise yesterday. When I pulled it out of the water to see what was up, I could spin the cylinder / housing between the prop and the skeg (or whatever it is) a little. If you turn it to just the right spot it works fine, but the slightest turn one way or the other and it's making noise again. Even after I turned it to the sweet spot, when I put it back in the water it would start doing it again almost immediately. It still works, but it sounds like a blender when I use it.
Any help would be appreciated!
