Had a problem with my 8 HP evinrude for the first time this weekend and I'd like some advice. Here's the story. We had a work tournament this past weekend at KY Lake. Got there Friday afternoon and took the boat out to scout some locations, covered 8-9 miles, used 1.5 gal of fuel and no issues. Got back to camp, disconnected the fuel line at the tank, pulled the tank out of the boat and filled it up from a portable 2 gal tank and reassembled (same fuel as run the day before). Tourney day, luanched the boat and parked, buddy pulled up to the bank to pick me up and off we went. Made it about 80 feet and motor died. I remembered I hadn't opened the vent on the tank, so I vented the tank and started the motor. Went another 100 feet and died again. I could keep the motor running if I would squeeze the primer bulb every 30 seconds, so that's what I did. I noticed though that when I'd squeeze the bulb some fuel was leaking from the connecting valve. The motor did run decent wide open, however, it did sputter later in the day and I had to prime to keep it going. My initial thoughts are to replace the fuel adapters (maybe the line too) and possible the fuel pump. If that doesn't work, move onto the carb. Sorry for the long post, I wanted to give enough background for information. Does anyone have any thoughts/opinions on this?
