Help with trailer for MonArk 1648
Bantou
TinBoats Supporter
Central Texas
While getting all of the trailer lights rigged up this weekend, I noticed some things with the trailer that concern me. The middle roller doesn’t fit the bottom of the boat well, putting all of the pressure on the center rib. I think it is also a little tall because there is visible space between the bottom of the boat and the runners for about the first foot or so.
Are these things ok, or a “down the road” fix, or a “fix it yesterday” issue?
There are also some issues with the winch/winch support that I’m probably going to have to address. The trailing arm is too tall and hits the eye hook on the boat while loading/unloading while also not preventing the boat from running all the way up to the winch.
I’m not sure if I should move it down and try to adjust the angle so the boat goes over the winch, or just move it down and add a flat bump stop like you would find on a pontoon.
Many thanks for the help,
Bantou
Edit to add: I know the bunks need new carpet at a minimum and probably just need to be replaced outright. The plan is to do that once I have the boat put back together and can leave it floating on my folks' pond for a couple of days.
    273.4 KB
    229.1 KB
    225.4 KB
    169.3 KB
That roller on the winch arm should contact the boat infront of the eyehook. The winch rope goes under the roller. That helps stop the boat from shifting forward.
I don't think that is the correct trailer for the 1648 flat bottom. The trailer looks like it is for a V bottom boat.
You may be able to make it work if you get rid of the center roller and make the bunks longer. The bunks should be sticking out past the transom by 2 inches or so and should extend forward to just where the boat rises at the front of the hull. Be sure your bunk at the front of the boat rests on a rib to prevent denting the boat bottom.
That seems counter intuitive but it does sit better on the trailer now. Thank you
It’s entirely possible that it isn’t the correct trailer. The boat and trailer were part of a lot from a creditor’s auction after the army corps decided not to renew the marina’s lease. I got the impression that they were just slapping boats on whatever trailer they would fit on.
As much as I don’t want to do it, I may have to take the boat off and put it on the ground for a few days. I’ve probably got enough scrap steel and lumber laying around to extend the bunks. Probably have to take an angle grinder to the roller. Just about every nut on that trailer besides the lugs is locked up with rust.
You are correct. The trailer looks exactly like a Haul Master 14-16 1000 which appears to be designed for a v-bottom jon. Looking at their flat bottom trailers, it looks like they just replaced the roller with a bunk run perpendicular to the trailer. That should be easy enough for me to fabricate.
When I purchased my jon it came with a sea-doo trailer. It sort of worked but I ended up replacing the bunks and adjusting other things to make it fit.
The trailer you have can be modified to work without to much trouble.
Have at er'.
Pulled the front roller last night but it was too cold to do much else. As per usual with this project, I found more that needs to be done once I got into it. The bunk brackets are rusted to hell and will need to be replaced. Center rollers also don’t fit the bottom of the hull and will need to be removed.
Is there any reason I can’t just bolt the new bunks directly to the frame?
I’m thinking 2-2x4x12s down the center and 2-2x4x8s down the outsides (all laid flat) should provide plenty of support. If I lay them flat, I could run carriage bolts through the frame without having to buy or make new brackets. I'll probably have to relocate the back up lights if I do it that way, but that shouldn't be a big deal. I left extra wire just in case.
    422.5 KB
    498.2 KB
    492.6 KB
    251.7 KB
I like the idea of using the four 2x4 on their side. It will provide very strong support. I wouldn't mount them direct to the frame, though. There are brackets designed for this and don't think they are that expensive.
You may need height adjustment to clear the fenders and to align with your winch post. They also allow for some angle adjustment, but might not be needed if it is a true flat bottom. If cost is the issue, consider only using one pair of 2x4s, which will still be more than enough support.
The boat rides between the fenders, so clearance there isn't going to be an issue. I'm actually considering adding a set of guide-on bunks to make sure I don't accidentally wind up on the fender while loading. The posts that are currently on there are set too wide and welded into place where I can't adjust them in. The back two are going to get new hardware and PVC Pipe extensions so that I can actually see where the trailer is while backing (it's narrower than my truck and too short/low to see over the bed, even with the boat on it). The front two will come off entirely if I decide to add guide-on bunks.
I see what you mean about the winch post though. As it sits right now, the 2xs are sitting flush on the frame and upright. That seems to line the boat up pretty well with the winch post. I don't have a good picture of it, but the post is adjustable. I'll have to look at it this evening and see if I am on the bottom hole or if it can be dropped down some more.
I have enough scrap steel laying around and the tools to fab up new brackets (I could even powder coat them if I wanted). I just really don't want to unless I have to; but, I'm too cheap to pay for something that I can make myself. Once I get the bunks, I'll do a test fit and see if everything fits without the supports or if I am going to need them.
Bunks went on yesterday. I cut pieces of 2x4 to raise the bunks up close to where they were before. Bunks should sit an inch or so outside of the bottom ribs. Guide on bunks are going on today, hubs are supposed to be in on Thursday, then I’ll test fit and cover the bunks. If everything works out, the boat will go to the welder on Saturday and then it’s all hands on deck to get her finished up for the spawn.
I don’t expect the 2x4 risers to last forever but the I’m hopeful that they will work for now. Worst case, they don’t work and I’m bank fishing the spawn again this year.
    263.5 KB
    240.1 KB
    418.2 KB
    224.6 KB
    152.6 KB
Guide-on bunks are done but I’m going to have to do something different with how they mount to the trailer. The brackets I got allow too much play and I’m worried they will either fail catastrophically or allow the bunks to walk out over time.
Supports are 3/4” EMT that I bent to roughly a 90. They should be plenty stout with how little the boat weighs.
    250.9 KB
    215.2 KB
    111 KB
    117.9 KB
I have a very similar trailer it's a 1970 Yarbrough. I'm doing the bunk on frame I will see if the skeg of my motor has enough clearance.
If you haven't yet you need remove the tongue and inspect the pivot bolt hole for elongation. The hole in my old tougue was out of round by more than 1/4". The 8' long 3x3 had many holes drilled in it and had a kink in it, I have replaced it with a 10' 3x3. I did away with the tilt by drilling 1/2" in the flat under the roller mount by the tilt latch. Also check the wear where the tilt catches.
If the EMT doesn't work I have seen smaller diameter exhaust tubing used. Have a muff shop bend them and mount them with U-bolts.
I’m doing away with the tilt as well. For now, I’m just going to clamp it shut using a flat plate and the 2x cross brace that I built.
Eventually, I’d like to run a pin through it where it is more secure than just a latch but I can tilt it if I need to.
All I have to do is remove the new bolt and it will tilt. If you think you will use the tilt function more often use a 1/2" hitch pin instead of a bolt.
By making the tongue 2' longer and knowing the ramps I'll be going to tilt won't be needed but I'm not doing away with it permanently.
I’m either going to get a bigger piece of emt that fits snuggly over the 3/4” and run it between the two sides or splice a piece of 3/4 between them. In theory, that should give me the rigidity I need without compromising adjustability too much.
I doubt I’ll ever need it. All of the ramps around me are pretty steep. I debated welding the two pieces together. However, I’d like to have it where it’s easy to use in the event that I do need it.
The 1/2” trailer pin is exactly what I was thinking. I’ll just have to pay extra attention when drilling because I don’t have a 9/16” bit long enough to go through both sides at the same time.
I carefully marked where to drill on both sides of the A frame and drill the holes with a step bit.
Well, TSC canceled the order for the hubs... They had an issue with my card, I called and was told it was corrected, and two days before delivery they sent me an email saying it was canceled. Apparently, the first person I talked to lied when they said that it went through and TSC didn't feel the need to communicate that they were still having issues.
No idea what the issue with the card was. All of the information was correct and there was plenty of money in the account. I guess we'll find out if Amazon hubs are worth the cardboard they ship in or not.
