I did a search on homemade livewells but couldn't find exaclty what I was looking for. I've got an idea in my head on how to make one custom for what I need. Due to size rqmts of the area I would like to install it during my mod, it's hard to find premanufactured that works one on ebay, etc... and I don't want to do the cooler thing (it works I just dont want it).
So, my plan is to use sheets of aluminum to make one. I'll cut all of my pieces (top, bottom, 4 sides) to the size I need, and on certain pieces I'll make 90 degree folds, making an approx 1" tab that runs the entire length of an edge. Once all of my pieces have been cut and all of the folds have been made, I'll clamp it all together, plumb it up, and rivet (I cannot weld) it along the tabs to make the finished product.
My next thought was to make it water tight by using an epoxy or some sort of waterproofing, and coat the entire exterior or interior, or both. This is where I don't know if it will work, or what's the best way to make it work. I'm also not sure if I want the inside of the livewell bare aluminum. Is it better to have it coated for any reason (besides noise reduction)?
Any and all advice, comments, or thoughts on whether you think this will work are greatly appreciated.
Crank'in
Crank'in
