jasper60103
spinfisher said:ditchen said:I am sure you will see a cylinder down on compression and you will have to pull the head.
If your lucky it maybe a bad head gasket, which is cheap and easy vs a rebuild.
I checked the compression 60 on one 65 on the other . Pulled the head and no scoring on the cylinders. Whats next?? The guy I borrowed the tester from said that this is common with the johnsons. I took a straight edge across the head and looks flat! Game is starting now, I'll check back later Thanks Spin
If it were mine, while the head is off, I would flush out the cooling system with a water hose on the water tube. Replace the thermostat and head gasket. Also, change the impeller/water pump.
