Makaw
Here’s the original propeller for my 1967 Johnson 20 hp model FD-21r, so it’s seen it’s fair share of water, mud, sand, debris..., as is evident in the photos.
How bad is it? Am I losing significant performance from the dings and bent sections? Will it help if I remove the burrs and minimize bent areas? Or is it past the point of being worth using?
Mainly asking to see how much of a priority I need to make a prop upgrade as I restore the boat (A. Upgrade asap! B. Meh, run it for a year and upgrade next winter! C. Nothing needed, it’s good for another 63 years!). Being a 9X9 pin-drive, my options seem quite limited. Would take general prop suggestions as well.
Some additional info if it’s helpful:
Boat is a 70’s era 14’ Starcraft side console. I haven’t driven in 10+ years, so no memory as to boat performance. Current upgrades are adding between 150-200 lbs of mid/forward weight, not including operator (185 lbs). Will mainly be using solo, but occasionally with 2nd adult. No idea on max rpm, other than I have a snippet from an old Johnson service manual stating 20 hp is produced at 4,500 rpm (I think this is simply a power curve reference, not related to max rpm). Manual also states idle speed in gear should be 550 rpm. No real concerns about top speed, more concerned about overall performance and holeshot, especially since I’m adding weight to the boat.
Photos below show current condition of prop. Johnson part #311484.
