sogafishin
- Joined
- May 10, 2009
- Messages
- 15
- Reaction score
- 0
I have a 14ft 48" wide V hull aluminum boat that I want to brace the transom .The motor I plan on using is a 1968 20hp Johnson.I nthink it weighs in about 85lbs.This boat and motor combo should be e great light weight combn the test run the transom would twist a little during hole shot other than that the boat handled it great.The only wood in the transom is a 2x6 up top.Would a peice of plywood added to the rear of the transom help my problem or do I need to start looking into a metal brace on the inside of the boat?Any ideas would be great. Thanks
https://i139.photobucket.com/albums/q297/kevinsauto/DSC00233.jpg
https://i139.photobucket.com/albums/q297/kevinsauto/DSC00234.jpg
