How to wire up batteries
calebpayne
Louisville, Kentucky
=D> Thank you guys for all your help!! I still your help. Now, how do you wire up two batteries located in the stren (rear) of the boat to control all the accessories for the boat. Trolling motor battery will be wire directly into the TW.
Thanks,
Caleb
PS, What size of main fuse should be used from the baterries to the console, I will have a fuse box for accessories with fuses for each current to accessory.
Again, thanks for all your help. I need it.
Can you give us a list of accessories you plan on having? The expected load will make a big difference on the best way to wire it.
sf
I just picked up a G3 and in the process of undoing a lot of saltwater corrosion, I'm redoing all of the electrical on it. It had a 20A(Seadog) circuit breaker and #8 wire going to the console. I moved that from the motor battery to the trolling battery because I did not want anything but the motor on the start battery. I can limp back to the dock with no lights if I have to, but I want that motor to start every time. Now, I have a 20A C/B feeding the console and a 50A C/B going to the trolling motor from the trolling battery. I've ordered a Blue Sea Charging Relay that should be here in a couple of days. That's a cool device. it combines both batteries when the motor is running so both get charged, but as soon as you shut it off, the batteries are isolated, so you can trol on a full batteryl without using the starting battery. The other thing I'll do is connect the positive poles of the batteries together with a Blue Sea on/off switch, so if my start battery does get weak, I can use both batteries to start the motor.
I've already replaced the nav lights and the bases they plug into. Initially, noting electrical worked because there were corroded grounds all over the place. My project tomorrow is to get rid of the electrical plugs under the console and solder and shrink wrap everything. This is a lake boat I bought to use for catfishing, but it's also going to do double duty at the coast as a bay boat and salt wreaks havoc on wiring. Also, all of the wire terminals are getting stripped back to new wire and connectors solderd on those as well. It's a pretty big job, but th electrical will be bullet proof when I'm done. After all of that, it gets a Racor water/fuel separator and then I'm going fishing.
Thanks,
Caleb
Sorry, I got carried away talking about the new toy. To answer your question, use a 20A C/B going to the console. You probably have #8 wire and that should be good. Each individual circuit should have it's own fuse for protection. Remember the purpose of a fuse or C/B is to protect the wire, not the device, so install the C/B 7 inches or closer to the batter positive terminal.
