nbaffaro
What russ has done is put light sockets at the front and the back of his boat. Run the power from you bus bar or distribution block to each of them. This way they have power all the time. They usually have some type of plug or cover so that they won't get water in them. When you plug in the light then you already have power and they come on.
Picture 1 is of the socket that would work.
Picture 3 is of the front navigation lights that will plug into these sockets
However, if you choose to go with a permanet type light like the one in picture 2 then you will need to wire up some sort of switch.
I would recommend even if you go with a permanet front mount that you should go with a removable anchor light so it won't be in the way during the day time. It should be at least 3ft higher than anything else on the boat. (I think)
