I painted over Steelflex...
SlowRollin'
Pearland, Texas
Well, I needed to get on with this project and wasn't happy with the current paint job so I thought I'd try a section on the transom and see what happens...not much.
I painted a 1' by 6" section with Tractor Enamel paint just above (below) the drain hole; waited a couple of hours, then tried to wipe it off. It wiped off fairly easy. A light coat of Mineral Spirits to get any remnants of the paint and is was completely clean.
I have a couple of stains on the bottom of the boat where the steelflex was applied and wondered if I could get paint to hold. Now I know. [-X
It was fun to find out.
Original and it's been sitting up for almost a year since I applied the steelflex. I roughed it up with a green pad and then just sprayed it. I'm certain the results would have been different had I tried to pain it within a day or two of laying down the coating.
I just wanted to know for sure if it would take or not...not this time.
How as the paint held up over the steel flex?
I painted my boat with the steel flex but I'm not really happy with the finish product. I would prefer not to have to sand all of it off the sides if I don't have to. I was thinking of doing a light sand and then using a self etching primer for a base coat to paint over it. Im just a little worried that the paint won't stick very well.
I just applied some spray paint over mine as a test. It is the new Teflon kind. So far it seems to have stuck. Time will tell.
