- Joined
- May 15, 2010
- Messages
- 3,725
- Reaction score
- 414
- Location
- Central Florida
- LOCATION
- Lake County, Central Florida
I got your PM and looked up this thread to reply to you. My Model R was a sad case when I bought her but she has paid me back in spades with great performance and smiles every time Lesa and I put her in the water. Well worth the work put into the boat.
There may be others on here much more adept at removing paint than myself but I will tell you what worked for me.
I went to a Sherwin-williams store and inquired about paint removers. I despise the ones that will burn you. In the store they have one that is Soy based. I bought it and it did a super job without burning your skin. Does not screw with the environment either.
This should be your first task. Second task for me was cleaning the hull with a phosphoric acid. This will clean the aluminum extremely well. Available at Pontoon boat dealers or your local hardware stores. Mix with water and use in a sprayer. Start from the bottom up to keep from streaking the hull. Have a water hose handy.
Third was using SOS pads on the inside and outside to remove what oxidation was left. Use water with them. They leave a super fine finish on the hull. You will feel the oxidation being removed as, all of a sudden, the pads get very easy to move on the hull. I never used sandpaper with these methods.
You asked about steering and controls cost. The cable itself is cheap. Springs can be had new or used. Cable clamps were new for safety reasons. Pulleys can be found used as well.
Steering bracket for the engine can be had used and they are pretty plentiful, make sure you get the quarter turn fastener with it.
The old control boxes are also plentiful in the "Simplex" style. The older period-correct one I used for this boat was a bit harder to locate. Just found a much nicer one this weekend to replace it with.
As I recieved it. Looks nice? Think again....that silver was a spray bomb job over the top of some awful brown goop that vaguely resembled paint.Inside and out!
Using the paint remover
You get the idea.........
Before using the SOS pads......A LOT of corrosion.
But after using the Phosphoric acid on the whole boat I started with the SOS pads. Note the difference on half of the bottom!
Hull finished with SOS pads.
I needed to remove some stubborn areas of paint around the rivets inside the hull. Also needed to prep the surface for Non-Skid. I used these instead of a wire wheel. AWESOME is the word for them. They are made by 3M and available at NAPA stores.
Found a steering deck from a model FD. Fit was close to perfect. Installed with aircraft blind rivets using Clico fasteners to retain position on the gunnels. Used a soft mallet to form the edges to the rounded gunnels.
Boat was pretty well finished at this point. I have a Cypress mill close to the house and Cypress just so happens to look an amazing amount like White Oak. I copied the transom pieces in Cypress for the inside and used a scrap piece of Mahogany for the outside. I used all the same holes as the factory and drill nothing extra into the hull.
Controls and steering are installed at this point. I have a mid-section from a 1954 RD-16 Johnson 25hp on it. Engine was not quite as advertised when I bought it from a fellow I know. Can you say blown powerhead. My fault for not checking but I trusted.......... not a big deal.
Okay....enough for now. I will get you photos of the steering installation and post them as well.
A couple of videos of the boat and what Lesa and I enjoy with it are here.
https://www.youtube.com/watch?v=mvKGt5jepVo
https://www.youtube.com/watch?v=mI6rUZU-Ff8
